I have created a dialog based program that opens an avi, reads a frame from the avi into an LPBITMAPINFOHEADER (lpbi) and does some manipulation of the bits. If I want the avi frame to draw to a section of the dialog window. How do I draw the bits from the lpbi to the dialog? Can I create a Picture Frame and somehow map to it? And how do I convert the bits from the lpbi to the fromat it needs to be to draw to it? I appreciate any help you could provide!
Results 1 to 1 of 1
AC3 music/dialog is split. Any way to combine the two?
By silvertoaster in forum AudioReplies: 1Last Post: 23rd May 2011, 19:34 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
AVI files displaying with wrong aspect ratio
By The111 in forum Newbie / General discussionsReplies: 10Last Post: 19th Mar 2009, 17:33 -
Finding The Right Dialog Normalization In Dolby Encoding
By seven_deuce offsuit in forum AudioReplies: 0Last Post: 28th Apr 2008, 22:25 -
removing music score without affecting dialog...
By rprevatt in forum EditingReplies: 1Last Post: 2nd Nov 2007, 12:57
