How do i find the file size according to a certain point on my svcd/mpg file so i can detremine the best place according to size and the movie scene to cut the mpg?
Any body know of any utilities the give you the size to a certain point in the movie?
Do not post the same question in more than one forum.
https://www.videohelp.com/phpBB/viewtopic.php?topic=65277&forum=10
Regards.
Michael Tam
w: Morsels of Evidence -
U car try flask/xmpeg >> mark the end point >> add the job and it gives the file size. I dunno if its acurate, but it's close.
I am going to try womble -see how it works
but i found out that if i multiplexed the mpeg before with bbmpeg as svcd then woble does not allow me to cut it as svcd only as mpeg program stream
do you know if i can add the svcd parametrs lost from bbmpeg again
or maybe i should multiplex it again only as mpeg2 stream in bbmpeg and then cut it in wombel demultiplex and remultiplex it in bbmpeg? -
well cutting in wombel after multiplexing as svcd in bbmpeg doesn't work - you loose the sound
Going to try the second method! -
well my mistake wombel does not do audio!
By the way does xmpeg just cut or does it rencode?
<font size=-1>[ This Message was edited by: nimrodo on 2001-11-08 12:05:13 ]</font> -
Try My flix v3 .
I use to split all my vcd and svcd with no prob's.
It give's you in easy to see, your cut point in frames if just half of whole wont do (svcd) then ( X frames by frame rate (25-pal etc)) will give you how many seconds you are cutting.
Not sure but I think it also back's upto last key frame when cutting (or forward depending)
Havn't been using myflix long but seems ok. -
Myflix is only good for mpeg1 not mpeg 2
As for your method fatboy i used the same method - but in wombel....but when cutting according to frame:
Lets say you found the middle frame - cutting at that point does not assure you of getting to files of the same or even similar size - as that depends on the bitrate allocated (in vbr) the each half of the film.
By the way the program equvilant to myflix for mpeg 2 is edit pro 2 or Myflix ex - pitty i can't find them in spain- if anybody can hep on this one i would be glad.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
Cutting a MPG FILE
By peekayem in forum EditingReplies: 3Last Post: 16th Mar 2008, 09:06 -
Cutting File size through muxing HD Audio
By Mastablastacious in forum EditingReplies: 1Last Post: 4th Feb 2008, 02:18 -
mpg to dvd keep file size
By bladerunnerx_x in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2007, 13:12 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 04:41
