Results 1 to 13 of 13
  1. Anonymous
    Guest
    I burnt my first dvd coaster last night. Have been burning for 4 months now without problems. I was backing up die another day when I received the following errors.(these came up at the same time.They are split for uploading)
    Any ideas?
    Jan 2003
    In the bath
    Faulty disc. Nothing more, nothing less
  3. Anonymous
    Guest
    Original dvd or writable
    Apr 2004
    The bottom of the planet
    I tend to find that most problems with DVDDecrypter can be solved by rebooting the PC and trying again at a lower burn speed. Although I suspect from that capture that you'll have to kiss the recordable goodbye.
  5. Anonymous
    Guest
    Gotta bump this cause it just happened with another backup disc. Can this happen if you are running other programs?Nothing heavy. psp8 editing a small jpg?
    The original plays just fine.
  6. Is it failing when trying to write the Lead-In? Am I reading those screenshots right?
  7. Perhaps its time to update the firmware and/or DVD Decrypter ?
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  8. Banned
    Oct 2003
    Americas
    That may be a corrupted image file or incompatible media (I vote for the 1st). Try ripping it again, this time to VOB's, check if playable and burn with NERO (video_ts folder).
  9. yeh id go with corrupt ISO.
    cant understand why some peeps want to burn dvds that way.
    i much prefer the raw vobs and bups.
    never had any problems until i tried the iso burns.
    mind you,i never haev to put my coffe cups on my unit any more.
    im spoiled for choice for assorted coasters now.
    my favorite being the ritek jaguar print cd-r.
  10. Anonymous
    Guest
    I'm lazy and the way I chose works 95% of the time.
    I guess the "burn proof" option doesnt work all of time.
  11. known fact that DVD Decrypter has trouble burning ISOs. you will find that your problems will disappear if you use any other burning prog to burn ISOs. There's that free one ImageBurn or something like that. or nero 5.510.42 is great fro image burns (that's what i use). anyway Decrypter IS the problem BURNING ISOs, especially in the area of using burn-proof, just-link, etc. great ripper, though.
    Apr 2004
    I have never had a problem burning ISOs with DVDDecrypter that weren't fixed by simply rebooting or inserting another disc. In fact, usually after I insert another disc, I will insert the one that it spat the dummy on for my next burn and presto... burns just fine.
    Considering the price, you can't argue with that kind of performance.
  13. Banned
    Oct 2003
    Americas
    Was it a thank you note to all those who cracked their heads about your problem?
