Hi guys
I try to make 5 second mpeg2 Movie to attach in beginning of already existing DVD. I use TMPGenc to encode the new file at following specs which is same with original DVD:
Bit Rate = 8 megabit
Size = 720x480
Aspect Ratio = 4:3display
Frame Rate = 29.97
Video Format = NTSC
Encode mode = interlace
DC component prevision = 10 bit
GOP = Standard
And “TMPGEnc's MPEG TOOLS” couldn't join them and said:
"File VTS_01_0.m2v is not compatible with MPEG file."
so I tried to read original info by ReStream and following image is the result:
There’s following different: (which ReStream was Unable to modify the original M2V file or even my file to match them in some way.)
- GOP
- Scan mode (Zig-Zag)
- SDE (Sequence Display Extension)
Please help me how to encode the new file that can be match with new file
PLEASE! PLEASE!
This is so urgent for me.
Seyed Mohammad
Results 1 to 1 of 1
need joining of 2 mpeg2 files.
By snafubaby in forum EditingReplies: 3Last Post: 21st Dec 2008, 16:51 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 11:54 -
ts files into m2v or mpeg2
By vertical in forum Newbie / General discussionsReplies: 124Last Post: 21st Jun 2007, 13:12 -
problems Muxing M2V and Aiff files to MPEG2
By bbaddorf in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 15:14 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 08:56
