  1. Hi I need help when copying my files onto a DVD+R.
    I currently have a Toshiba DVD-ROM SD-R5112 drive. When I have previously ripped on to a Sony DVD-R it worked perfectly without hassle.
    Now, however, I have purchased Memorex DVD+R but when I place the disc in the drive, it does not recognise it.
    Does anyone know if this is a problem with the drive? Someone has suggested to me that DVD+R may not be compatible with the drive. Does anyone know of anyway to make it compatible?
    I am using DVD-Decrypter and CloneDVD software.
    Any help will be greatly appreciated!
    [/quote]
  2. murraywalker18,
    First of all, please do not put a subject line like this. Please read the forum rules. It means it's hard to find answers to questions when searching the forums, and many users will not even read a subject titled like this. Secondly, please avoid posting in bold. If I'm reading it, I'm reading it!
    Thirdly, and most importantly, please do your own research! I searched for your writer in the "DVD Writers" tab to the left of your screen, and within 30 seconds I had an answer.
    Here is your answer! Your drive does not support + media.
    Searching for an answer yourself will often save you time, and it saves my time too.
    I'm not having a go at you, so don't worry.
    Regards,
    Cobra
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Apparently it's a problem with your drive.
    And no, you can't make it compatible with +R.
  4. i also have a toshiba 5112. it is only -R, you cannot record +R
