Hey guys, its me again, with another problem I need help on. Here is what I got:
Swap Magic 2.0 Discs
Verbatim DataLife DVD-R
v7 No-Solder Modchip
My problem is this: I backed-up a successful copy of Hitman Contracts, and I found out I needed to get the CdLoader Fix.
Well I put the Swap Magic CD Version in, Swapped with CdLoader, Swap back to DVD Version, and then finally put my back up of Hitman Contacts in, and I get a screen with a green galaxy, and a red border. I dont think that is a good sign. What do I need to do in order to play this game? What did I do wrong?
I burned with DVD Decrypter, ISO Read, ISO Write. (I set it to burn at 1x, but it automatically put it back to 2x).
Any help is highly appreciated!
Results 1 to 15 of 15
I think you might have read this but if you hadn't
http://home.rochester.rr.com/ps2ownz/cdloader.html -
you might try the dvd version of v7all..
http://www.ps2ownz.com/forums/showthread.php?t=11133
if you're not registered, you probably wont be able to d/l.. -
Thanks for the link, is this supposed to be burned on a CD-R? Data Mode 1?
What's the purpose behind DVDLoader, is it the same as the Cdloader FIX, but especially made for DVD's? I guess CdLoader didn't cover ALL the games? -
Ok, do I burn it on a DVD or Cd-R? And how do I burn it? Any special settings?
Ok now this is my problem:
I have burned the DVDloader succesfully on a Verbatim DVD-R. When it tells me to switch the disc, I press the eject button, switch discs, and it says "Media: Invalid Disc". Why is this?
I thought maybe it was because I burned it wrong, but then I tried building a GI with RecordNow MAX, and it made 4 of them. So I didn't burn, because I didnt want to make a coaster.
Whats with this game? How do I get it to work? -
Sorry, I'm not sure I understand what you mean...
None of my other backed-up games need the DVD loader. This is my first time with DVDloader and/or CDloader. -
you dont NEED the dvd loader, it just eliminates swaps.
and when i said try a different high TOC game, you know how you have to insert a game (or SM2 dvd) original that has a larger TOC than the dvdr? try a different original. -
Ok, now I understand what you mean.
I found out my problem though, it was the back up of Hitman Contracts. I got the green galaxy with green border.
So I burned another copy with RecordNow MAX at 1x, and it works great!
Why when I set DVD Decrypter at 1x, it automatically goes back to 2x? How can I fix that? I have the newest version. -
DD is for encoded dvd flicks. PS2 games are neither. So why don't you use Nero dvd copy? use the right media too & always give all your specs so we know what you are doing it with.
I use DVD Decrypter, because that what everyone says to use. I feel more comfortable about making copies with a program that everyone gives the "Thumbs Up" to. But I'm sure Nero DVD is probably just as good.
But either way, it's just weird how even though I set it at 1x, it automatically goes back to 2x.
Ps2 Burning Problem
By waazzaa101 in forum ComputerReplies: 17Last Post: 21st Jun 2012, 19:47 -
Hitman rip, repeated scene
By jntaylor63 in forum DVD RippingReplies: 7Last Post: 17th Dec 2008, 07:13 -
Hitman BD disc
By bimboppin in forum Blu-ray RippingReplies: 8Last Post: 30th Mar 2008, 06:43 -
cant bypass HitMan BD with AnyDVD 6.4.0.0!
By nightshade11 in forum Blu-ray RippingReplies: 4Last Post: 21st Mar 2008, 08:53 -
hitman blu ray disc?
By bimboppin in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 10:22
