hi everybody,
does anybody know how to create a svcd, where i can select between two languages?
thanks in advance
Before posting:
1. Read all the guides on this site (menu to the left)
2. Use "search" (top of the page)
3. Check out other web guides (e.g., doom9's site at http://www.doom9.net )
You will have to encode the audio separately. Then, simply multiplex both languages to the video with bbMPEG.
Regards.
Michael Tam
w: Morsels of Evidence -
hi,
thank you for your advice.
as i unterstood, it is quite dificult to make it.
anyway, thanks anyway.
i will be looking for solutions
regards
Blu Ray to MKV with optioinal multi-language audio/subtitle support
By minerva.thegift in forum User guidesReplies: 10Last Post: 6th Oct 2014, 03:53 -
Multi-Language Subs
By DeathStalker77 in forum SubtitleReplies: 34Last Post: 29th Nov 2010, 00:13 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
DVD Multi audio language-how to make it
By arvin in forum Authoring (DVD)Replies: 4Last Post: 10th Jan 2008, 16:33 -
Can't get other languages out of multi language idx/sub
By diskdocx in forum SubtitleReplies: 0Last Post: 7th May 2007, 20:55
