i have problems ripping DVDs that are a bit scratched with shrink and decrypter both had problems is there anyway i can copy the movie still
Best way -
Buy your own disc scratch repair machine and use that whenever you have difficulty ripping anything. Unless the scratch is so deep that you can see light through the scratched area (which means the actual data layer is destroyed and the disc is worthless), it can be saved. A disc repair kit will save you big amounts in the long run. -
There are places that repair discs. There's one near where I live.
Give the disks a real good clean with some soap and water with a soft cloth to dry. If that shows up loads of scratches etc then you can either buy one of them machines to hopefully clean the disk or take the cheaper route... Toothpaste and oven cleaner can work as can brasso, if you do a forum search you will find a good thread on this subject somewhere.Originally Posted by RevMyOh
Remember to only polish in straight lines from center to edge or edge to center NEVER round the disk......Not bothered by small problems...
Spend a night alone with a mosquito
Good SATA drive for read/ripping scratched or damaged DVDs
By darkin in forum DVD RippingReplies: 2Last Post: 19th Nov 2010, 01:47 -
scratched discs
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 18:42 -
Recovering scratched audio CD
By Des in forum AudioReplies: 11Last Post: 31st Mar 2008, 08:54 -
Are some DVD burners better than others at reading/ripping scratched DVDs?
By davlor in forum DVD RippingReplies: 11Last Post: 2nd Dec 2007, 16:03 -
What player for scratched DVD's?
By mad_max911 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Sep 2007, 10:43
