I found a movie I want to download with from a newsgroup(dont worry no names), It is in 2 parts. CD1 and CD2. They are both 900+MB. The first file is said to be 923MB. How the hell is that supposed to fit on a 80Min cdr? I know they can hold 800 or so MB in mode 2, but 923 is WAY to large for a cd. Why would they format a movie so both disc, really cant be on one disc? And I found many movies like this.
Results 1 to 9 of 9
A bird in the hand is worth a foot in the tush-Kelly Bundy
Once you get into (S)VCD territory, it's about minutes, not megs (most of the time.
Bottom line: Download it and try to burn. Qwitcher bitchin' :P -
But I wanna piss and moan! LOL
923MB on a cdr, this would be a first for meA bird in the hand is worth a foot in the tush-Kelly Bundy -
With VBR encoding its true that the amount of minutes you fit in X amount of space will vary with the bitrate, but the limit is still always going be the size of X. A blank 80 min cdr holds about 800MB's. Regardless of how many mins the SVCD is, if the filesize exceeds this then it won't fit, not accounting for overburning. These files you see will not fit on an 80 min cdr.
My only guess is that they are intended to be overburned on a 90 min cdr or to be put on 99 min cdrs. -
Originally Posted by TheEverLiving
Is that missing something? I'd say so! :P
Download it, try it on a 99min cd, if not extract the mpeg and reencode
My machines a little slow for reencodes. To do a 2 hour movie in VCD the encode time is 6-8.5 hours. At SVCD, it always was pushing 12+hours.
So how the hell did they do this??!!
By Chilla1142 in forum EditingReplies: 9Last Post: 1st Jun 2011, 09:46 -
Deliver Me To Hell - An Interactive Zombie Movie
By freebird73717 in forum Off topicReplies: 0Last Post: 2nd Aug 2010, 18:02 -
How to watch ".cd1-mongodlx.r00"
By indiego84 in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2009, 20:59 -
How can i combine 2 sub files (languages) into 1 sub file? (NOT cd1 & c
By Spixe in forum SubtitleReplies: 2Last Post: 4th Jun 2008, 08:33 -
How would I append segments of Bin/Cue Cd1 and Cd2 ?
By Hittz in forum Authoring (VCD/SVCD)Replies: 5Last Post: 23rd May 2008, 06:49
