This is wierd, I think that when I did the SVCD hack a few weeks ago, I changed one of the PROM settings (I was subject to the effect of a cuppla beers!!)...
This is what now happens. VCD and SVCD play perfectly. Any DVD that I put in the player plays for a few seconds, then stops itself. I have tried a few different things, changed the PROM back to what I think is the original for this player (55 53 00 55 16 55 00 FF), factory reset, turning off PBC in the menu...
The only thing I can think of is that these values have changed (when I tried factory reset on different occasions, although the PROM was set differently, it was not changed by the reset... would there be another way????)
If someone could help me get this sorted I would be incredibly grateful!!
Thanks!!!
leave PBC on.
as for the PROM settings,you should have written them down.
or maybe someone who owns one,will know them.
I want to convert video so that they are 3 times the original playing speed
By Joey.G in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2010, 09:49 -
playing Digital8 tapes in 8mm tape backup drive
By jrh69ca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Dec 2009, 12:46 -
Problem Playing Copied DVD+R DL DVDs from CSS Protected Original
By bpbenda in forum DVD RippingReplies: 10Last Post: 24th Sep 2009, 09:04 -
By bpbenda in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2009, 13:42 -
Panasonic DVD SA-HT743 stopped playing Original DVDS
By chankya in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Dec 2007, 16:38
