Hello. I tried to look my problem in the forum, but couldnīt find.
Iīve been trying to encode an AVI (DivX5) file to DVD MPEG-2. The file is encoded with 23,976fps and from what Iīve learned, DVD must be encoded in 29,97fps with 3:2 pulldown. But when I do so, my MPEG-2 file length gets smaller than the original, the video arquive is smaller than what was predicted with the bitrate calculator and the video looks slightly faster too.
Any idea about how can I fix it would be highly appreciated.
Thanks.
You are increasing the number of frames played every second by 29.97 - 23.976 = 5.994 frames every second. This makes your videos shorter - you are literally playing them faster.
There is nothing you can do but accept this as a fact of living with NTSC. I, on the other hand, have PAL which is 25fps always! :P
https://www.videohelp.com/dvd - Check down the bottom by NTSC Technical Info.
Cobra -
Leave it at 23,x and try to make it 23,x (29.97 internal) instead. If you stick to the wizard it'll make sure it's set up properly for you.
MKV with Variable Framerate convert to MP4 problem
By beaniekapp in forum Video ConversionReplies: 12Last Post: 4th Jul 2010, 08:44 -
HELP - MKV reference framerate change problem
By danielo in forum Video ConversionReplies: 5Last Post: 20th Aug 2009, 06:22 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 17:14 -
Framerate problem when muxing
By baconharvester in forum EditingReplies: 3Last Post: 17th Sep 2007, 18:35 -
converting framerate problem
By Shaorin in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 00:00
