I recently got the Chappelle's Show complete first season and it comes on 2 discs. I've been using DVD2One to rip movies, but this is kinda hard. I wanna rip the total discs to the hard drive and then combine them on 1 dvdr. If this is not possible I'll settle for being able to only rip each episode and put them all on 1 dvdr and have them play consecutively without a menu, like the "Play All" option the main menu of the original dvd. There is a total of 12 episodes, plus extra material and commentary for about 4 episodes. Some of the other tools I've installed and worked with are DVD Decryptor, DVD Shrink, AnyDVD (which I use with DVD2One to rip), and CopyToDVD to burn. I'd greatly appreciate any help with this situation.
thanx in advance
You're going to lose a lot of quality by putting them all on one DVD. Are you ok with that?
P.S.- "I'm Rick James, bitch." -
why would I lose alot of quality? I've read the forum for a few days and I've read the part about movies being able to be compressed by shaving the excess bandwidth and that this process decreases quality alot more when dealing with episodes because they are usually recorded at low bandwidth, but exactly how much will I lose and whats the process to do that so I can see the results for myself. As of right now, I can't use DVD2One to rip to hard drive because it only has options for 'join', 'full disk', and 'movie only'.
HELP PLEAsE -
I already downloaded and installed DVD Shrink. I have both discs of Chappelle's Show Season One on my HDD but now I want to combine them onto 1 disc if at all possible. If this is impractical please let me know and I'm open to suggestions about a resource (dvd+r) saving method of backing up the Complete Season. I'm even open to trying new software to rip or compress, which I usually don't like because new software requires that much more time to learn and understand in order to use it like an expert.
Thanks in advance for your help -
That sounds like a plan, I'ma try that. Thanx man, I really appreciate it.
I'll let you know how it comes out.
Peace
rip episode, subs, choose size
By Nucleus in forum DVD RippingReplies: 1Last Post: 7th Jul 2011, 02:51 -
Help needed adding Subtitles to Multiple Episode DVD with SubtitleCreator
By colditz in forum SubtitleReplies: 5Last Post: 20th Jan 2011, 19:41 -
Single Episode Rip with MINIMUM Re-re-re-re-compression - HELP!?!
By jdmba in forum DVD RippingReplies: 6Last Post: 8th Aug 2008, 09:45 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
Splitting episode dvd to 2 discs
By parman in forum EditingReplies: 3Last Post: 12th Sep 2007, 16:05
