I converted the enclosed movie, My.Cousin.Wedding.Movie.avi, to VCD using ffmpegX and it looks like, it divide the movie in three .mpg plus one .mp2.
My first question is: wich file is a VCD so that i can burn it on Toast and watch on a personnel DVD player, Panasonic R-32?
My.Cousin.Wedding.Movie-3.mpg
My.Cousin.Wedding.Movie-2.mpg
My.Cousin.Wedding.Movie.mpv
My.Cousin.Wedding.Movie-1.mpg
My.Cousin.Wedding.Movie.mp2
Question #2: Is that the proper way to be able to convert .avi to VCD?
#1: You need to author the 3 .mpg files into .cue/.bin pairs, one for each CD. To do so, rename your files so as there is no space or special character in them (or in their path). Then click the Tools tab and select the first .mpg in the first "Browse" field. Enable only "Author as VCD" in the right side. Click the "Author" button which will create the .cue/.bin pair. Repeat for the other 2 .mpg files. Burn the .cue/.bin pairs with Toast 6.
#2: Yes. If your files doesn't have spaces or special characters in their names or path, the above .bin/.cue pairs will be created automatically at the end of the encoding process.
Thank you, I did try to author the the files with no success. I try with some other files and still no success, I'm only getting .mpg, .m1v and .mp2 files no .bin/.cue. Do you think that I miss something in the installation of ffmpegx.
I put my file in the Open.... */Film DVD/Filmavi.avi/xxxxxxxxx.avi and then press the Quick Presets button. In the Tools icon it does put it automaticly in Author as VCD .bin/.cue.
I'm i suppose to do anything with, under Video Tools 1. Select file to process and 2. launch processing Mux as VCD....
Extension .sfv
By Jomapil in forum ComputerReplies: 8Last Post: 13th Nov 2015, 07:06 -
.PS to any video extension
By wazza88 in forum Video ConversionReplies: 3Last Post: 2nd May 2010, 21:56 -
extension TLX
By surfer in forum Video ConversionReplies: 2Last Post: 31st Aug 2009, 03:19 -
MediaShell Extension
By alsghrla95 in forum Video ConversionReplies: 1Last Post: 1st Aug 2009, 02:40 -
Extension .IMG
By Jomapil in forum ComputerReplies: 7Last Post: 17th May 2009, 09:52
