OK....I don't have a firewire card. I really don't want to get one if it can be avoided, as I only need to capture one video to my computer, and then forever after that I won't need it.
I've heard of DV-to-USB (haha, preferably usb 1.1)cable? So I can hook up the DV side to the camera and USB to computer and somehow capture that way. I read some posts about this dropping frames, but I dont really need lossless quality, as it will eventually be put on VHS anyway.
My problem: I did google searches, ebay searches, bestbuy.com, compusa.com, staples.com etc etc etc and I can't find one of these cables! Anyone know what they are called, or where I can find one?
Quicker = better, I need this very soon![]()
Results 1 to 12 of 12
-Yar, matey!-
you can get a firewire card for like 15$ (maybe less) -- going to be cheaper than a firewire to usb convertor (if one even exists)
Only firewire cards ive seen are exat least $30, + the cable...
-Yar, matey!- -
Go to Pricewatch.com and check under video capture. There is a 4 port firewire card listed for $9 with free shipping.
There is definitely no such thing as a Fireware-to-USB cable. They are two completely different standards. It would require some active electronics to convert between the two.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=31752&Sku=A...5516&CatId=510
or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=673999&Sku=...8000&CatId=510
You'll still need a cable, which will be more expensive than the card. Make sure you get the right cable. There are 6-6 pin, 6-4 pin and 4-4 pin. -
I got a cable with mine.
The ******** at Best Buy want $25 for the cable -
Hey, thanks guys. I thought I had seen something about usb cables (someone on some archived topic in this forum had mentioned getting a usb cable with his dv camcorder, but said it didnt work?), but I couldnt find them anywhere...I guess im gonna be forced to buy a firewire card (or edit with a VCR hooked up...haha)
-Yar, matey!- -
ST Lab firewire cards comes with cable, very cheap, worked every time i used it so far.
O_o o_O thanks guys....hehe. But I solved my problem. I found a friend who has a video capture card (although analog, since its going to end up on VHS in the end, it should be fine, right?)
-Yar, matey!- -
just try it and see if ok .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 11:25 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 02:14 -
Capture Card and Virtualdub Problem
By TV107 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2008, 17:35 -
Capture card problem
By Phaze72 in forum Capturing and VCRReplies: 7Last Post: 13th Apr 2008, 17:31
