when i try to (bakup) a dvd
this is what it say`s Failed to read from file
is there a way to (bakup) a dvd and fix this it happen`t to 20% of the dvd`s that i have
What sort of dvd are you trying to back up retail or dvdr ?
What software are you using to back them up ?
What state are the disks in ?Not bothered by small problems...
Spend a night alone with a mosquito -
dvdshrink30beta5
DVD X Copy XPress
state of dvd`s is good
burner and reader 8X LG
dvd 9 Band of Brothers dvd 2 and 5
1 3 4 where good
is there a program or somting that can fix this ro software that can reat over it -
I would suggest that you give the disks a good clean with a soft cloth to remove any finger makes etc and then have a real close look at the disk, bet there are some circular marks somewhere.
You could try dvdcrypter as you can tell that to ignore read errors unlike shrink which just crashes out.Not bothered by small problems...
Dvd shrink failed to read file e:/
By patty304 in forum DVD RippingReplies: 12Last Post: 7th Nov 2010, 13:34 -
"Failed to read video frame"
By jva1254 in forum EditingReplies: 1Last Post: 25th Sep 2009, 06:59 -
Avi to DvD .failed. "Cannot read .m2v ?
By ukel12 in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2008, 10:47 -
failed to read the video data from the source file (80004005)
By tertill in forum Video ConversionReplies: 3Last Post: 31st Oct 2007, 10:26 -
DVD File Allocation Failed
By Emeraldas in forum Newbie / General discussionsReplies: 8Last Post: 22nd Sep 2007, 09:26
