    Aug 2003
    Canada
    i was starting to shrink Italian Job and after 10 minutes it shows this error
    ...."cyclic redundency check" and stops
    how do i rip it then?? or are there any other programs
  2. Banned
    Jan 2004
    Going in Circles
    try cleaning the disk or try dvddecrypter. Sometimes shrink will hiccup when ripping.
    Aug 2003
    Canada
    how do i shrink the file size with dvddecrypter????
  4. Banned
    Jan 2004
    Going in Circles
    once you rip with decrypter, then shrink with shrink. just select open files then look for video_ts.ifo. This is the movie, then you can shrink it
    Aug 2003
    Canada
    damn decrypter has an error too i think the disc is scratched
    Mar 2003
    Chicago,IL
    I've had problems with damaged dvd also. I have a fast dvd rom for ripping (16x) and if I put the dvd into my sony dru-510ax to rip (only 2x) it will sometimes work, since reading at slower speeds seem to do the trick on some dvds. Depends on how bad the dvd is.
