I've noticed that most of the Simpsons episodes that I download are really bad quality. Are there any filters to apply in TMPGEnc to make the quality better? I've heard this is possible with cartoons.
Thanks,
Dhruv
I only dream in black & white...
MSN: paschendale@gmail.com -
There really isn't much you can do with a poorly encoded file. I'm assuming that when you say "bad quality" you are referring to "blockiness". If so, you can try using some of the smoothing filters (like 2D Cleaner or Smart Smoother) for Virtual Dub to make the blocks less noticeable. You could also try using the noise reduction filters in TMPGEnc under the "Advanced" tab.
<font size=-1>[ This Message was edited by: N0SoopForU on 2001-12-11 19:22:18 ]</font>
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 23:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 10:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
