After encoding files to vcd it often says something like insert a larger cdr.
If i can't get that file to burn,is there any way of saving that encoded file for burning another time,or would have to encode it all over again?
Also can you batch encode files with Nero 6?
Many thanks for any help given....
This may not sound very helpful but never encode with Nero. It's one of the worst mpeg encoders around. It gives you no control over encoding settings and quality usually suffers because of this. Use TMPGEnc instead. It has a batch mode and if you are only making VCD's(mpeg-1) it's freeware. Only the mpeg-2 encoding is limited by a 30 day trial. Once you have your VCD compliant mpeg created, use Nero to burn only.
I have tried other encoding software before and whilst it does encode the films it doesn't have any sound.
Do you have to encode the sound seperately or something?
Sorry to be a pain but i am pretty new to all of this.........
Many thanks... -
This is the best advice you will get, couple it with reading the guides on the left and you will be home and dry.Originally Posted by teegee420
It's always a good idea to decompress your avi's audio to wav and use the wav file in TMPGnc as the audio source. Open the movie with Virtualdub, go to the audio menu and select "full processing mode", then go to the file menu and select "save wav". If your avi has ac3 audio you'll need to install the AC3 ACM Decompressor before using Virtualdub.Originally Posted by Humbug
meGUI Nero AAC encoding error
By ArtOfLosingMFZB in forum DVD RippingReplies: 4Last Post: 16th Aug 2010, 13:46 -
Nero Recode encoding problem
By goodmedo2003 in forum Video ConversionReplies: 4Last Post: 30th Apr 2009, 11:35 -
nero smart encoding
By m baqar in forum Authoring (DVD)Replies: 4Last Post: 27th Mar 2008, 06:13 -
nero 7 out of sync encoding
By sharky007 in forum Authoring (DVD)Replies: 1Last Post: 25th Jul 2007, 05:28 -
Question for Those Who are Familiar with Nero 6 or 7 on Encoding to MPEG-2
By wayney in forum Newbie / General discussionsReplies: 11Last Post: 13th Jun 2007, 20:35
