Hi, accidently I used ULEAD MS 6.5 (I normally use MS 6.0) for converting an 1 hour DV-avi to PAL SVCD (Constant Bitrate 1350, audio joint stereo 160 Kb/s).The result by 6.5 was different from the reult off 6.0.The SVCD couldn't be play back without stuttering frames while 6.0 SVCD runs smooth. Anyone else encountered the behaviour?
I encoded a dv type 1 avi to svcd (pal) with MSP Director's Cut V6.5 using your settings and it played back fine. Director's Cut V.5 is the 'supposed' to be the same as MSPV6.5 less the graphics and paint plug-ins.
I'll try that with type 1 again.Mine was Type 2 (output from VirtualDub). Let's see what happens.
I transcoded the type 1 to type 2 and got the same results.
<font size=-1>[ This Message was edited by: Lamont Cranston on 2001-11-08 08:10:57 ]</font>
EasyCAP w/ Ulead and Pinnacle - Video Stuttering/Jumping/Lagging problem
By Logan289 in forum Capturing and VCRReplies: 0Last Post: 30th May 2010, 15:25 -
how to create avi from mpeg2 with only I-frames?
By ecc in forum SubtitleReplies: 3Last Post: 20th Feb 2008, 08:14 -
MKV to MPEG2 - Not dropping frames, but not smooth - think it's audio
By Shade00 in forum Video ConversionReplies: 11Last Post: 18th Feb 2008, 14:20 -
swf to avi - last few frames of animation get cut in the avi - any solution
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2007, 09:01 -
Trouble when saving MPEG2 Ulead VideoStudio 10
By faramith in forum Video ConversionReplies: 3Last Post: 13th May 2007, 10:17
