Using the "reauthor" function of DVD Shrink, I have created several clips of different segments from one of my DVDs. They now reside in separate folders on my hard drive. I want to burn them to a single DVD-R.
Can this be done? For example, with TMPGEnc DVD Author, which I have?
Further complication: What if these segments have subtitles? (TMPGEnc DVD Author doesn't support subtitles, right?)
Thanks for any help!
Just do it in DVD Shrink. Just do a re-author and drag each of the segments to the left side and you're all set. Just make sure the subtitles are checked if yuo want to keep them.
In108, this guide should help with your question:
https://www.videohelp.com/forum/userguides/198813.php
Mixing 4:3 & 16:9 Segments Onto One DVD
By DeathStalker77 in forum Authoring (DVD)Replies: 2Last Post: 18th May 2010, 20:21 -
Question how to make multiple cuts with DVD Shrink
By jimdagys in forum EditingReplies: 9Last Post: 20th May 2009, 20:19 -
Best/Easiest way to make multiple segments of a mp3 file?
By raydeneg in forum AudioReplies: 4Last Post: 7th Oct 2008, 09:47 -
dvd shrink: single large file or multiple small files
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 22:43 -
DVD shrink fails to rip home recorded dvd in multiple sessions
By sybariten in forum Authoring (DVD)Replies: 9Last Post: 21st Aug 2007, 22:42
