I don't have a dvd burner. My friend, who created his movied on a MAC doesn't have a good authoring program, but he does have a burner. I used Encore to create some great menus with his vid. I exported it as a DVD file(Video_TS) and a data2.0 (I forgot what its called). I then Transfered to MAC. No matter what I do, IDVD can't understand it. Am i basically screwed? Is there a format I can encode it to? MAC won't understand ISO's or BIN's
no.
iDVD is the authoring app for mac.
Your friend could have authored the app with that and burned it afterwards. No matter....
Mac can understand ISO and BINs also by the way.
what burning software does your friend have? Hopefully Toast. You can easily burn the ISO or BIN with that app like you would on a PC.
Tell you friend to visit https://www.videohelp.com/forum/viewforum.php?f=9 if he/she wants to learn more on how to use iDVD and or where to find other free authoring apps for Mac that will save you all this hastle in the future! -
Great thaks for the info,
the only reason we were using encore on a pc is because we wanted to create menus with a better software app than idvd. idvd wasn't reading the bin when i tried to transfer it, but i never thought of toast. Thanks
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 06:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 23:13
