I have a Xvid avi it's a TV capture from a sporting event and I wish to convert to VCD.
Yaai says the following:
480x352
29,9706 fps
When i put source as 1:1 VGA in Tmpgenc the result was a slightly stretched image. Which of the following option should i choose?
4:3 525 line NTSC
4:3 525 line NTSC 704x480 (whats that?)
4:3 Display
The source aspect in TMPGEnc should be 1:1 for an AVI (I have found, anyway) and the video arange method (under advanced tab) should be "Full Screen (Keep aspect ratio 2)".
Here's a useful link for TMPGEnc:
https://www.videohelp.com/tmpgencexplained.htm
As I say, this might not be right but it has always worked for me. Give it a try with a small sample of the video and burn to a CD/DVD-RW and see what it turns out like.
Hope this helps,
Cobra -
Thank you, however how does one decide the aspect ratio of the source?
Is the resolution the sole deciding factor so that I can simply calculate the aspect ratio from the horizontal and vertical resolution values?
It seems people are capturing in all kind of strange resolutions that are hard to convert to 4:3 or at least close to 4:3. -
Best Deinterlace settings for this source?
By alcOre in forum Newbie / General discussionsReplies: 32Last Post: 22nd Oct 2015, 16:24 -
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 20:44 -
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 10:35 -
AVStoDVD: How do I make default settings for all files to aspect ratio 4:3?
By Heyjoojoo in forum Authoring (DVD)Replies: 8Last Post: 30th Aug 2010, 23:49 -
Aspect ratio
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2010, 12:25
