You can put 1 marble in it, after that it is not empty... :POriginally Posted by daamon
Results 151 to 180 of 376
Where is the Deadly Viper Assasination Squad, when you need it ?
Correct - Are you a lateral thinker, or did you know it already?Originally Posted by ChrOThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
i couldn't put any marbles in an empty bath, as i have no equipment designed for usage in a vacuum :P
I suppose that's an equally valid answer, albeit tangential to the lateral!!!Originally Posted by flaninacupboardThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I thought it had to be a trick question, because you cant calculate it, it depends on how the marbles pack together...Originally Posted by daamon
Here is another puzzle:
You can move 2 match sticks, to get the spider out of the glass, and i mean outside the glass... (the glass has to look exactly the same afterwards.)
Where is the Deadly Viper Assasination Squad, when you need it ? -
@ChrO: How's this:
Okay, a square with 9 uniformly spaced dots as shown below. Take a pen and draw only 4 lines, without picking up your pen or backtracking over an already drawn line, covering every dot :
Hi ChrO,
I've PM'd what I think might be the answer - just in case it is right and others want to have a go...
EDIT: @ SquirrelDip - Not being funny, but I'm guessing Chr0's after a description (diagrammatic / worded) of how you did it... I ended up with the same arrangement, so I guess we did it the same way...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
This one is hard!!!Originally Posted by gll99
I have solved it, but the last house needs a cell phone...
Both Daamon and SquirrelDip.
You are absolutely right.
It took me longer...
@SquirrelDip, like this?
I agree - It sounds like I've got to the same point as you...Originally Posted by ChrOThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
New Puzzle: "9 Dots, 10 Lines"
You have to draw 9 dots on a flat sheet of paper such that 10 separate straight lines can be drawn, with each line covering exactly 3 dots. What is the arrangement of the dots?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Take four 9's and only four 9's. Arrange them any whay you like and apply any mathematical function such that the result is 100.
i.e.
(9 * 9) + 99
99 + 99
etc... -
"Four 9's" - Solution?
(9 / 9) + 99 = 1 + 99 = 100
This is relying on the mathematical rule that brackets means that the operation contained in them is done first.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
@daamon/northcat_8 : Both correct! This is actually a good puzzle for the grade school kids...
@daamon : Correct on your rule, however, according to mathematical rule the brackets are not necessary (but do add clarity). -
New Puzzle: "Large Hands"
Using only your 8 fingers and 2 thumbs, what's the highest number you can count up to? Please supply your reasoning with your answer.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
LOL... Don't know if this is where you're heading with the "Large Hands" but I'll guess 1024 (or 2^10). Gotta have pretty good dexterity though...
The classic (wrong) answer - close, but no cigar.Originally Posted by SquirrelDip
EDIT: Right thinking, but its 2^10-1 = 1023. 2^10 in binary is 10000000000, i.e. 1 with 10 zeros - 11 digits, but you only have 10 digits - I hope! - So the max is 1111111111 (10 1's - represented by all 10 fingers up), being 1 less than 2^10. Hence 2^10-1.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Is the answer to the house and services problem to simply draw your lines back around the other side of the paper and over the top?
1/4 dollar problem .. the reason why it is not correct is that you are using fractions and integers.. any fraction squared becomes smaller unlike an integer which gets larger (except 1)
eg 1/2^2 = 1/4
2^2 = 4
In maths mult & div precede addition and subtraction (I think)Corned beef is now made to a higher standard than at any time in history.
No, the problem has to do with the units. daamon and Northcat_8 have augued that since the square root of a dollar is meaningless you cannot take the square root of a dollar and hence the square root of (1/4 dollar) = (1/2 dollar). My point also dealt with the units in so much that you must take the square root of the units even though they are meaningless.Originally Posted by RabidDog
We've had much debate on the above point. We are all augueing the same error but we have a dissagreement in details. daamon and Northcat_8 will argue that mathematically you must have similar units or the equations are not valid, I am argueing that the math is correct regardless of the units as long as the math is correctly followed. -
RabidDog
Thanks for trying but no. That would be the same as extending the page and would have no effect. You could draw this setup on a sphere and go all the way around and it still would not solve it. You need to stay on the visible page but except as stated in the puzzle, you can scribble anywhere in continuous lines to link the house to it's 3 services. It's a loophole in my rules more than anything else. The puzzle is normally impossible to do (which would have been no fun) but I left a path open in my description which makes it possible to do. Remember! Our minds create restrictions where there are none. Hope that makes it easier now.Is the answer to the house and services problem to simply draw your lines back around the other side of the paper and over the top?
Can you go under the utility companies to provide services?Originally Posted by gll99
Hello. -
then the services are simply connected one to each house then from house to house eg one line from each service as below
RabidDog
My rules:
Do you think you are breaking the rules?You must connect each service to each house by a solid line but it does not have to be straight. Each line can only go to one house and you must not cross any of your lines nor go through any other house to bring the service in.
Tommyknocker
Draw a picture.
Who owns the zebra?
It helps if you draw the houses and write the things you know for sure. Nothing is guesswork. There are variations of this puzzle posted on the net with different nationalities, animals and cigarettes etc.. I recently found a solution posted on the net from a few years ago which was wrong because someone said he tried this color here and then that color there until he made it fit. That is the wrong way to solve this.
It is mostly a process of elimination. As a realistic but ficticious example:
At one point in the logic, 2 nationalities (call them A and B) can only go in house 2 or house 5. A third nationality (call it C) can also go in house 4 or house 5.
What does that tell me. it tells me that A and B must occupy house 2 and 5 even though I am not yet sure which one. That point is not important right now. What is important is that if A and B must occupy house 2 and 5 then C must go in house in house 4.
Much of the logic is like that.
I redid it twice without writting down my logic and came up with the same answer. next I will have to redo it and write down my logic step by step so that I can present the explanation along with the solution.
I'll wait another couple of days and start posting step by step logic a bit at a time if no one else does. -
Please don't - I'm in the process of working it out...Originally Posted by gll99
Same goes for the "Houses and Utilities Suplliers" one - That one's a b*stard!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
daamon
Check out my comment to Tommyknocker. The solution may disappoint you.Same goes for the "Houses and Utilities Suplliers" one - That one's a b*stard!
Who owns the zebra is fun. I'll wait a while longer. Remember everything should fall into place through elimination. There is no trial and error involved.
btw) the island native at the fork in the road where the natives tell the truth all the time or lie all the time has not been solved. I will post the right way to get the road to town within a few days if no one guesses that one. It is not the same as a similar one posted earlier because there is no way to tell if the native you have encountered is a truth teller or a liar. -
gll99 -
I was just going to let that one go by but...
I'm on it, don't post the answer for a few days. -
@ gll99 - You're evil...
If the answer to "Houses and Utilities Suplliers" is disappointing, I will hunt you down...
As for the lying (or not) native - I give up. Post the answer as and when you want to... But, I will hunt you down...
And "Who owns the zebra?" On the case...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Can you solve this puzzle?
By tin2tin in forum Newbie / General discussionsReplies: 8Last Post: 15th Apr 2012, 23:54 -
VirtualDub filter to insert video from another source into a corner?
By Riothamus in forum EditingReplies: 2Last Post: 6th Jun 2011, 08:51 -
Picture looks like a puzzle of 1000s of small blocks
By Twheels in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2009, 13:58 -
Vobsub causing pixelation on upper RH corner?
By Uzysuicide in forum SubtitleReplies: 2Last Post: 7th Feb 2008, 18:13 -
Puzzle of Camstudio AVIs
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2007, 16:01
