Results 1 to 13 of 13
    Apr 2004
    tasmania
    my dvdshrink will copy my backups of single movies but not my backups of "multis" any ideas???
    Jul 2003
    michigan
    since the backups are already compressed, ju8st use dvd decryptor to write and burn as an image file
    member since 1843
    Apr 2004
    tasmania
    thanks i will try that, it is actually e drive it cant read not e file
    Apr 2004
    tasmania
    where will i find dvd decrypter??
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Do you think that DVD Decrypter is highlighted red and underlines when you mouse over it for show ???
    It is a HY-PER-LINK. Click it to get more information regarding DVD Decrypter. Including where to download it.
    If in doubt, Google it.
    Apr 2004
    tasmania
    ok, have downloaded it and clicked decrypt, what do I do after that?? please help
    Apr 2004
    tasmania
    sorry wasnt red and underlined when i wrote it
    Jul 2003
    michigan
    click--mode--iso--read, when it's finished-mode--iso--write
    member since 1843
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Go to the mode menu. Go to ISO submenu. Go to Read. Specify your destination file. This will write an ISO image to your Hard Drive. Once done, go to the mode menu. Go to ISO submenu. Go to Write. Specify the ISO image just created. Click the Hard Drive --> DVD button and you are done.
    Apr 2004
    tasmania
    so I do it all in decrypter, dont use shrink, and thanks for the help ricky i am new to this and really appreciate the help
    Apr 2004
    tasmania
    thanks jimmalenko, excellent directions (still at 87% decrypting)
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Cheers. Although ricky beat me to it
    The thing to note is that this will only work for commercial DVDs that are 4.35GB or less, or any backup you have on DVDR. If you have a commercial DVD that is > 4.35GB, you will still need to use DVDShrink.
    Apr 2004
    tasmania
    thanks guys, backup completed successfully!!!!!!
