  1. Is it possble to demux (seperate audio and video) on a DiVX 5/ *.avi file ?
    If yes, how can I do it ?
    .. Thx for taking time to read and reply
    - Zo
    <[也::Freedom of information is a right, not a crime::[也>
  2. Use Virtual Dub. On the original one, open up the AVI, then FILE/SAVE WAV. Then AUDIO/No Audio. And I believe at that point you can then save AVI AS... with direct stream copy for Video
    O.
  3. thx man, fast reply
    - Zo
  4. naaa... I was thinking about keeping the vid and skipping the audio tho...
    Got a home made movie with... Want to replace the sound with some music and stuff..
    - Zo
  5. didnt see your edit
    working on it now.. lest see if its working...
    - Zo
  6. I did forget something in the first try tho 'direct stream copy'.. my new file was like 500% larger.. hehe... but, on direct stream copy / no audio.. it worked.. thanks for the help man
    Perhaps you can tell me how to join a divx5/*.avi and mp3 ?
    - Zo
  7. Member teegee420's Avatar
    Dec 2003
    Southern California
