  1. I have encoded my video through TMPGENC 2.5, bit rate at 5200 (m2v) then authored using TMPG Author and Adobe Encore on 2 different brands of DVD-R using my sony 510A dvd burner. About 20 of the discs i have burnt have had troubles playing all the was through on any one of my 3 dvd players. The picture got jagged or froze. With the PS2 it was unable to read the disc after playing for a while.
    The only successful burn was using my cheap standard bundled software Sonic My DVD.
    It dring me crazy.
    Thanks for any help.
  2. I don't know if it's really the solution, but it's a good idead to perform a Get VTS Sektors with IFoEdit. Open any .ifo file of your VIDEO_TS folder, and just klick on Get VTS Sektors (it's in the lower part of the screen). If it says that Sektors were corrected than this is probably the solution.
