  1. I'm having a problem capturing sound while capturing video.While capturing video I hear the sound just fine though my computer sound. When I play back the capture video it has no sound. I enable audio on the preference setting. Any ideals would be helpful...-Thanks !
  2. I have a sound blaster live sound card. My sound for my capture comes in on my line/in on the sound card. Make sure your sound card is recording from the right input. In my case I can enable the mic, the line/in at the same time and hear both coming through my speakers. I can independently record the mic though which would explain why you might be able to hear the sound but if it's recording the mic input or another input this might be why your capture isn't getting any sound. I ran into this problem myself. I hope this helps.
  3. Thanks ! Myke, You were right my sound card was set up to record under the Mic input. It recorded fine under the mic input.If you have other insight on recording audio with video I would be greatly appeciated. Once again Thanks for your help.
