Page 2 of 2
FirstFirst 1 2
Results 31 to 42 of 42
  1. i will rma then , i guess i'll wait for about 1-2 weeks to see if the new one works , anyone know if newegg will notice that i flashed it?
  2. What does your Driver File Details say under the Device Manager, your dvd player and the driver tab>Driver Details.... Mine says this:
    c:\WINDOWS\System32\DRIVERS\cdrom.sys
    c:\WINDOWS\System32\DRIVERS\imapi.sys
    c:\WINDOWS\System32\DRIVERS\PxHelp20.sys
    c:\WINDOWS\System32\DRIVERS\redbook.sys
    c:\WINDOWS\System32\DRIVERS\storprop.dll
  3. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Imapi is WindowsXP built in burning software, this should be disabled anyways. Check your taskmanager to see if it's running and kill it. Disable the start up service from the system management console.
    PxHelp20 is TMPG DVD Author's old burning engine, based on the PX engine (Prassi, RNM), but it was later moved to the Gear system.
    CDROM and Redbook are default system files
    not sure about storprop, most likely store properties?
    Jul 2003
    michigan
    you might have a problem with your aspi , try forceaspi
    member since 1843
  5. ok, so should i do a manual install of aspi force drivers?
  6. Also in my drivers my drive has SCSI in the title, i don't have scsi though. Is this ok?
  7. nvm f*ck this piece of shit, i'm RMAing it on monday, shouldn't have to deal with this kind of shit, never had any problems like this before...
  8. Status: RMA'd
    Sending out today 2 day air, i'll let you all know if the new one works
  9. got the new one in today, omg was it a pain in the ass. I checked my tracking # on fed-ex's site and it said it was delivered around 11:00 a.m. but the package was nowhere to be found, after calling fed-ex and seeing if it went to the wrong place, and ending up getting nowhere i assumed it was stolen. So i was about to call up and see if i can get ANOTHER one, but i went out to go to my uncle's house and noticed a package sitting on my neighbors porch, went over and sure enough it was mine. Slapped her in and it works fine! I'm not flashing this one or anything this time. Come to think of it, when i first got the original one the chip at the back bottom right corner was kinda burnt, this one is shiny and green. I assume that it was screwed before i got it. Now nero works fine with the disc's it originally couldn't read! Thanks for your helps mate, i'm sure i'll be asking some questions in the near future...
  10. Member teegee420's Avatar
    Dec 2003
    Southern California
    Glad to hear the replacement worked out. I'll bet you sure feel vidicated.
  11. yeps^^ burned 3 discs so far and no probs w/ NERO thx mate
  12. told you to take it back......that was your luck....
    see ya :P
