I have 2 hard drives with Windows XP installed in both drives one for use and one as a backup. I was having some trouble with my newly built pc. It kept rebooting. So I decided to do a clean install. Problem is the setup failed and it keeps rebooting. And since I got the problem fixed on the original installation, How do I prevent setup from starting every time I start my computer. You know in the beginning when it gives you a chance to choose the OS? Can I delete it.
Hopefully the drive you do not want to boot is a slave on the cable and the one you want to boot is the master.
Go to your BIOS and goto the "Boot" menu and select the HD with the working OS on it. If they are similar HD's and you don't know which one is which, then just unplug the bad drive, go to your BIOS and see what the numbers are for that HD and then plug the other one back in and set the good one as the boot drive. It should boot to the good drive and show the bad OS drive as a secondary drive which you can then reformat.
You could also take out the good drive, plug in the drive with the bad OS, let the system post, hit F8 and select command prompt and just reformat it. -
Right click "my computer"
Properties
Advanced tab
"startup & recovery" settings button at bottom
click "default OS button"
select the "Good Install"
I have a blank screen when booting
By edong in forum ComputerReplies: 4Last Post: 17th May 2010, 00:19 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
booting problems
By romanstopme in forum ComputerReplies: 11Last Post: 8th Sep 2009, 14:58 -
New PSU and system not booting it seems...
By doublelayer in forum ComputerReplies: 5Last Post: 18th Jun 2008, 14:21 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 13:23
