  1. my question is if you have like hmm four video clips and one menu.
    and then you play the vcd and select a clip from the menu it plays BUT instead of flowing into the next clip can it return back to the main menu?
    any help would be great guys thanx
  2. You need a program that can create menus. For the simple example you asked, Easy CD Creator and Nero can do it I believe.
    VideoPack4 is a much more powerful VCD authoring program.
    VCDImager is also very powerful but lacks a GUI.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Get yourself winoncd then check out the guide at http://www.coyote01.freeserve.co.uk
    Good luck
  4. Well i aquired Video Pack 4.0 and tried the tutorial from that link you gave me and i donno it was hard to follow and when i got it all down it gave me an error messg.
    i tried to record a IMAGE of what i made with menus and mpgs
    the error messg was,
    "you must specify images for node 'videocd:1' "
    and i have nooooo idea what that means
    is there a better tutorial out there for use of the videopack? cause i hear that it can create way more dynamic menus
    thanx for the help
