I just installed a 160g slave drive on my system. I also have a 120g external drive connected w/firewire that I have used for video editing and capturing. It has worked terrific.
Would I get better results (dropped frames and such) by capturing on my new slave drive? it is a 7200rpm IDE
thanks!
dp
Personally I would use the slave drive to capture, but then that is my own preference. I have a Seagate Barracuda 120GB 7200 HD as a third hard drive (through a IDE PCI card) and have not had a dropped frame yet.
I don't have one, but I just feel tht an external drive would be ideal for backup storeage mainly.
Hope that this helps.
Cole -
I use my slave drive for all video capture and editing. I use my external drive for storage of finished DVD's. I normally save the finished product in iso format, then burn it from the external drive when needed.
Either one should work fine. If you have a problem with dropped frames (and such) with one then use the other.
Slave
Can I capture DV footage through my external drive?
By Batman Sausage in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Feb 2011, 11:55 -
capture from digital 8 can't be saved to external hard drive/uploaded FTP
By vci1000 in forum Capturing and VCRReplies: 13Last Post: 2nd May 2009, 06:39 -
external hard drive to capture to?
By safaje in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Apr 2008, 21:25 -
Videos stutter from internal drive, but okay off external drive
By ruggrock in forum Software PlayingReplies: 7Last Post: 22nd Jan 2008, 13:17 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
