Hi everyone,
I have a damaged vcd disc that I want to fix. It contains a 600mb .DAT file (typical vcd format) on it. The movie/vcd plays fine with one exception. It freezes at a point halfway through the movie. The parts before that point and after that point plays smoothly. I'm guessing its due to a scratch.
My question is, is it possible to fix this by burning/copying the vcd using some program or other? I can't copy the entire DAT file to the HD due to the scratch. Is there a way I can record/copy the first half (up to the glitch), and then record/copy the second half (after the glitch) and repaste them together?
Thanks in advance,
Tony
Try isobuster at http://www.isobuster.com
It can extraxt the mpeg and handle minor scratch.
Or use Tmpgenc to extract it to 2 halves,jump over the problem area and join them .
There is a gude how to use Tmpgenc oon the left this site.
Two .mp4 files - corrupted/damaged? - help
By swalk in forum Newbie / General discussionsReplies: 12Last Post: 15th Feb 2011, 22:40 -
Any New Software that fixes damaged MTS files??
By deanna_v in forum MacReplies: 3Last Post: 1st Sep 2010, 03:33 -
Converting Damaged VHS Tapes to Files on a HDD
By RhoXS in forum Capturing and VCRReplies: 5Last Post: 20th Feb 2010, 08:40 -
Recovering damaged dvd files FYI
By Starman* in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2008, 10:32 -
Is there anyway to copy damaged DVD discs?
By Rockstar452 in forum Authoring (DVD)Replies: 9Last Post: 30th Nov 2007, 12:00
