Hi there
I use Intervideo Dvd copy 2 to backup my dvd's but I have a problem...
On some dvd's after succefully backup when i put it into my standart dvd player the dvd doesn't jump automatically to the menu of the film... It says disc error and I need to select the menu manually... I think that that happens because the dvd doesn't have a root menu but I'm not sure...
So, can you give me some tips to use Intervideo Dvd Copy 2 ?
Many thanks
Can it play in U PC 'normally'?
It happen to me as well.
That is why I am back up in 'movie only' this day. Even with DVD-5.
I use DVD Shrink to shrink or compress it if need be, retaining all the menu's in the process... I then burn with Intervideo DVD copy 2... If it doens't have a root menu, it will most probably do what you say it does...Selecting it manually and going from there...
Yes on the pc everything goes well...
So, it may be because of the root menu...
Tks for the answers...
Intervideo DVD Recorder in Vista?
By jubbely2 in forum Capturing and VCRReplies: 0Last Post: 13th Jun 2008, 12:40 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12 -
intervideo dvd
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 10:37 -
Power DVD Copy Problem
By Tel in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 16:51 -
dvd copy problem
By ht0160 in forum DVD RippingReplies: 10Last Post: 1st Jul 2007, 17:31
