I have just bought a dvdr70,I am very pleased with it ,recording from satellite box.My only concern is the strange metallic buzzing noise it makes when I power it up from standby.Can any other owners confirm whether this is normal or does my player have a problem.
Well mine does make a noise when powered up, but I wouldn't have described it as a buzzing so I'm not sure if it's the same sound as you're getting. Mine just makes a short mechanical noise which I always assumed was something to do with the drive/laser assembly aligning itself.
TV makes a buzzing sound when scenes are bright.
By Denvers Dawgs in forum Newbie / General discussionsReplies: 10Last Post: 30th Nov 2011, 11:32 -
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
How to Remove Audio Buzzing?
By Tchail in forum RestorationReplies: 5Last Post: 1st Sep 2010, 04:13 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
Filtering Buzzing Noise from Audio
By Tchail in forum RestorationReplies: 4Last Post: 12th Sep 2007, 23:49
