Hey im using Canopus ProCoder to convert my movies from avi to dvd but how am i sapose to know which video reloution size to use becuase all my movies are differnt resolutions?
When in doubt, use 352x480/576(NTSC/PAL). Anything larger will only magnify the avi's flaws.
You'll find varying theories on capture resolutions. You're converted video resolution is also up to you. Lower res means you can use less bitrate, which in turn means more video on a single DVD. I capture my stuff at 368x480 and crop to 352x480. I convert right at 352x480 with between 3000 and 4000 CBR bitrate. The audio can be pretty easily fixed if it is consistently early throughout the video. Virtualdub for one will do it...
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Video resolution (image size) calculator
By headless chicken in forum MacReplies: 10Last Post: 15th Jan 2011, 18:17 -
How much does resolution affect file size?
By milkydoo in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 18:29 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57 -
Converting resolution size
By Illusionist in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2008, 02:38
