1) between
prodisc 4x DVD R+ vs Verbatim 8X DVD R+ , which one shd I get ?
I can;t get hold of 4X R + for verbatim and I understand that 8x could be unstable
a) or should I just settle for 2.4x DVD R+ by verbatim ? ..what's the time diffce in burning a 4.7 GB data on this 2.4 x vs a 4x DVD R + media (written at 2.4x and 4x speed respectively ) . I should avoid DVDV R - 4x by verbatim I guess vs the DVD R + choices above
2) to burn a 4.7 GB video , how much is the time diffce between a RAM 2x compared to RAM 3 x Panasonic ( ALL WRITEEN ON A DVD RAM DRIVE LG 4082 which writes up to 3 x) .For RAM 2x/3x, drive will be writing 2x/3x respectively
a) are there known reliability issues with Panasonic RAM 2x /3x , it is very affordable compared to the renowned Maxwell RAM
3) how is DVD RW + 4 x prodisc or cmc . Should I not buy it and try to get hold of DVD RW + 4x by verbatim datalife plus
How do you reckon Prodiscs are pieces of crap have you used much of this pioneer certified Class A media?Also I have burned over500+ 4x S03 and 100+ 8x R03 and guess what not one coaster plus they all have tested very well so faithfoo I would find you some Prodisc +R 8x R03 $.60 at Rima.com Class A mediaOriginally Posted by nufan292
James B Elder
Verbatim DVD+R AS GOOD AS Memorex DVD+R?
By snafubaby in forum MediaReplies: 6Last Post: 10th Sep 2011, 01:23 -
Verbatim DVD+R 100 pack vs. DVD+R single jewel case
By GSP_87 in forum MediaReplies: 6Last Post: 13th May 2011, 06:00 -
How did the fluke good DVD-Rs from Ritek & Prodisc come about?
By Bix in forum MediaReplies: 3Last Post: 19th Aug 2008, 16:23 -
Canadians - Verbatim DVD+R and DVD-R on sale Source at Circuit city
By victoriabears in forum MediaReplies: 1Last Post: 19th May 2008, 21:36 -
Problem burning to Verbatim DVD+R DL with DVD Decrypter
By spyder67 in forum Authoring (DVD)Replies: 6Last Post: 14th May 2007, 18:49
huh
