hi,i'm continuing to have a quality problem on one of the comedy series i burn.its a series called fawlty towers.its only 6 half hour episopes but when i shrink it using dvd shrink then burn using ic7 the episodes are all poor quality(pixelated).i've burnt other comedy series(father ted) with no trouble.indeed father ted contains 10 half hour episodes and the quality is fine.anyone have any idea to improve the quality on this?.any help much appreciated.......lee
First on to your question: Have you tried any other programs for transcoding besides DVDShrink? Have you cut out any unneccisary audio streams? Any unnecessary extras and stuff?
I don't know... I was having trouble with a married with children dvd and DVDShrink, and I just used a different program and the quality was fine.
Fawlty Towers.. hehe does it have the one where they change the sign to Farty Towells.. that's my favorite episode. -
Back it up using a different method (dvd rebuilder, half the episodes with shrink as still frames).
You cannot compare DVDs like you're trying to. Just because dvd 1 has pixelization and dvd 2 has nothing to do with one having issues and the other not. If the dvd with more episodes was encoded by the studio at a lower bitrate, the picture quality may not be as crisp, BUT, it's not going to have pixelization because it was mastered to fit its low bitrate. Transcoding will pixelate the hell out of a source that has a very high compression. Lowering the bitrate (reencoding) will soften the picture and create a little more noise but probably eliminate the pixel problems.
Or if you want to stick to DVDShrink, just make the first 3 episodes perfect quality and the last 3 still frames. Then do a second disc where first 3 are stills, last 3 are perfect.
pixelation during compression
By asiafan in forum Blu-ray RippingReplies: 2Last Post: 26th Feb 2011, 12:29 -
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 14:52 -
MKV pixelation
By Nicely in forum Video ConversionReplies: 4Last Post: 6th Apr 2010, 13:31 -
Pixelation Problem
By Renta in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 23:46 -
disappearing pixelation
By AlecWest in forum Off topicReplies: 5Last Post: 29th May 2007, 10:24
