Hi all, i'm trying to encode an xvid with 576x240 resolution with tmpgenc. I can get it to work with 16x9, but with full screen the video is stretched(coneheads..lol) I have searched all over for a way to fix without any luck. Is there settings that anyone knows of that would correct this problem?.... or am I stuck with having to watch 16x9 dvd on a 27 inch tv. Thanks in advance
Results 1 to 11 of 11
Did you try using 1:1 (VGA) aspect ratio in addition to selecting full screen(keep aspect ratio)?
On my first attempt I had 1:1(VGA) with full screen(keep aspect ratio) and it stretched it. I have tried other combo's with the same result, except for 16x9. Have you had success with that resolution converting to full screen dvd?
I'll give it another shot and post back tomorrow.Sure have. Using the settings in my last post.
The first attempt I burnt dvd...playing in powerdvd.Sounds like WinMedia Player 6.4. Have you tried it in another player?
Didn't try that..but I will.To fix the problem in tmpgenc is goto settings/advanced/clip frame/arrange setting and choose center(custom size) and adjust away.
Thanks for the responses...will post back with results. -
I had no luck with those settings teegee420, must be something i'm doing wrong? I used the center(custom size method 720x340) like johns0 said, and it worked like a charm. Thanks for all the responses, I really appreciate it!
Apparently you did something right because you solved the problem. Good for you.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
Problem watching BBC iPlayer files in full screen
By Cole in forum ComputerReplies: 17Last Post: 10th Mar 2009, 13:05
