Let me first tell you that I'm not precisely knowledgable concerning PAL and NTSC playback compatibility, especially when concerning video playback from the computer to a TV. My current concern is if there would be any problems with playback of a video file encoded using the 29.971 FPS NTSC standard, to a television or VCR equipped for viewing PAL. The usage here is just for viewing the AVI file, not for recording it through the VCR. While to my knowledge I know that VCRs in the UK and in Europe are equipped to accept only a PAL signal, my main concern is if that's the case with TVs and if so, if this type of setup (with using a TV-out) is going to create a problem for people to playback and view files. If there is a problem with video playback, is there a solution to correct this type of problem at the user end, without having to re-encode the video file to a PAL format?
Thanks in advance,
Eldric
Results 1 to 1 of 1
Pal 25i to Ntsc question
By spiritgumm in forum Video ConversionReplies: 17Last Post: 15th Dec 2011, 19:16 -
PAL to NTSC question
By rayden54 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Apr 2011, 22:59 -
PAL vs NTSC Question
By cottage in forum Video ConversionReplies: 26Last Post: 6th Jul 2009, 10:53 -
pal/ntsc lcd monitor question
By scotstrength in forum Media Center PC / MediaCentersReplies: 0Last Post: 30th Oct 2007, 13:17 -
PAL + NTSC Compatibility Issue !?
By ells6363 in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2007, 13:37
