This is a newbie question, but if I cut & edit a clip (avi, m2v, mpg, etc.) in a program like TDA, premiere, nero express?, then create a recomplied version of the file, will I lose any quality?
What happens or what does not happen in such an event?
Thanks!!!
pcexpress-guy
Edit as much as you like, but when you export the file, make sure you are not using any "compression" on the file. In premiere (thats what I use, and know the most about), you would want to select under "Compressor" NONE. When you compress a movie, you lose quality.
Need free Video editing program that works like regulay 8mm editor
By rwisdom in forum EditingReplies: 0Last Post: 18th Nov 2010, 13:04 -
Lossless AAC file editor?
By sldvd in forum AudioReplies: 1Last Post: 26th Oct 2010, 18:28 -
MPEG Layer 2 video file, is it an editor friendly file type?
By ferran275 in forum Video ConversionReplies: 18Last Post: 16th Apr 2010, 23:41 -
compress AVI file for future editing with minimal loss of quality
By samoyed in forum Newbie / General discussionsReplies: 4Last Post: 9th Feb 2009, 02:53 -
PSP video file editor
By efiste2 in forum Portable VideoReplies: 1Last Post: 27th Jun 2007, 18:07
