    Jan 2003
    Deep South - La
    in general if I use a tool like TmpgEnc to "multiplex" a mpg, is there any lost of quality in the issue? (Is this thing transcoding my video? or is just putting it together for me?)
    Thanks!!
    pcexpress-guy
  2. Just putting it together, no loss of quality.
    Jan 2003
    Deep South - La
    Is it clear when some quality lost issue will occure when using a so called editor type program?
    It seems some editors do transcode on their own without notice. I'm I right about that?
    also what free/tool editor here will just edit a file?
    Thanks!
    pcexpress-guy
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Depending on what you put into the word editing, almost all editing results in a reencode of the mpg. Some editors claim to just reencode the part where the edit has occured, buit I haven't tried it myself.
    Simple cuts ought to be possible without reencoding at all, but that's about what you can get away with without reencoding at least some part.
    /Mats
    Jan 2003
    Deep South - La
    If I just cut a video, it just gets recoded and not compressed/transcoded. indivual frames are left as-was before, just some get chop out and others get moved(encoded) to a new file.
    I think this is the distinction, yes?
    ahh... not sure.
    pcexpress-guy
