  1. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    I can't seem to get anything to recognize the file type. It all says invalid file type so I was wondering if there is something or some way I can convert the file into a new format recognizable to all software. Right now the only thing that will play the .avi files is Divx player but everything else says it's not supported. What should I do since I would like to watch these files on a regular DVD player.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sounds like a codec issue. Does WMP play it ? Have you re-installed the latest DivX codec ? Can you identify the codec it is using ?
    If in doubt, Google it.
  3. get avicodec to identify what codec the file is using
    then download it
    my money is on "divx 5.11" or "xvid koepi 1.0 rc 4" playing it
    if you want to convert to a dvd which works in a regular dvd player then check out the guides
    strange question for someone with 500+ posts on a video conversion site
    unless this is a one off file that that is using some weird codec
    i came across the on2vp3 codec on a file a couple of weeks ago
    just use avicodec to find out what the codec is then search the forum for it
    if i were a bookmaker i would offer odds of 100-1 that its already been talked about :P
  4. Member pyrate83's Avatar
    then download it
    Alright, thanks for your suggestions. As for my 500+ posts, I mainly post in the off topic forums but I have never dealt with burning these types of files to DVD to be played by a DVD player. I usually just stick to DVD backups which I have down now and no problems at all. But thanks again for your info.
  5. Originally Posted by pyrate83
    then download it
    thought you may have been another mod wannabe trying to trick people into talking about downloading copyrighted material then reporting them
    glad your not 8)
  6. Member teegee420's Avatar
    Dec 2003
    Southern California
    How messed up is THAT?! Now we are starting to question the validity of the questions?!
  7. Member pyrate83's Avatar
    That's sad if that's what some people here try to do. I can only hope that there aren't that many DVDrhelp forumers that try to pull that.
  8. Member pyrate83's Avatar
    Hey really neat program, got the appropriate codec to play the files and voila, now I will be able to burn them to a DVD.
    Thanks as usual! :P
