  1. I'm trying to convert a dvd to divx using doom9's guide found here:
    http://www.doom9.org/gknot-main3.htm
    My problem arises when I try and rip/demux the video using robot4rip. Using all of the default settings, I get the error message "Error: Indexing/demuxing failed: Can't create process." and then the program gives up. I've tried using different dvds, and I've tried ripping the dvd first (file mode) and then pointing r4r to the folder. Nothing works. Any help would be greatly appreciated. Thanks.
    The full log (with the source set to the dvd ripped to a folder by dvddecrypter):
    9:45:23 PM: BEGIN RIP "dvddecrypter" - 4/27/2004 9:45:23 PM
    9:45:23 PM: robot4rip (0.5.0.1090) - WinXP (5.1.2600.2)
    Title: dvddecrypter
    FileName_ISO: H:\DVD\ISO\dvddecrypter.iso
    FolderName_Vob: H:\DVD\Rips\dvddecrypter_VTS_04_PGC1\
    FolderName_Prj: H:\DVD\Projects\dvddecrypter_VTS_04_PGC1\
    pgc: 0
    angle: 0
    redirect: off
    active_ISO: False
    active_pgc: True
    active_indexing: True
    active_audio: False
    active_vobsub: False
    active_chapters: False
    active_finalize: False
    rip_from_DVD: False
    extractBitmaps: True
    IfoInfo:
    Path: H:\DVD temp folders\dvd decrypter\
    ShortName: VTS_04
    ChainsCount: 4
    HasAngles: False
    H:\DVD temp folders\dvd decrypter\VTS_04_1.VOB
    H:\DVD temp folders\dvd decrypter\VTS_04_2.VOB
    H:\DVD temp folders\dvd decrypter\VTS_04_3.VOB
    H:\DVD temp folders\dvd decrypter\VTS_04_4.VOB
    H:\DVD temp folders\dvd decrypter\VTS_04_5.VOB
    H:\DVD temp folders\dvd decrypter\VTS_04_6.VOB
    H:\DVD temp folders\dvd decrypter\VTS_04_7.VOB
    H:\DVD temp folders\dvd decrypter\VTS_04_8.VOB
    pgc 1: 2 chapters, 12 cells, 1 audio streams
    pgc 2: 2 chapters, 12 cells, 1 audio streams
    pgc 3: 2 chapters, 11 cells, 1 audio streams
    pgc 4: 2 chapters, 11 cells, 1 audio streams
    VobSize: 8190597120
    Anamorphic: False
    Audio Stream 1
    Demux: True
    Language: English
    NumChannels: 2
    CodingModeName: AC3
    Stream: 0x80
    Encoder Setting: 1
    Subtitle Stream 1
    Demux: True
    Language: English
    Subtitle Stream 2
    Demux: False
    Language: Espaņol
    PGC details:
    Num: 1
    ChainTime: 00:42:41:59
    Angle: 0
    CellCount: 12
    Available Audio Streams: 1
    Available Subtitle Streams: 1 2
    9:45:23 PM: PGC Rip
    9:45:23 PM: Creating destination folder "H:\DVD\Rips\dvddecrypter_VTS_04_PGC1\"
    9:45:23 PM: Copying Ifo file
    9:45:23 PM: Using vStrip
    9:45:23 PM: Saving temporary voblist
    9:45:23 PM: Ripping with C:\Program Files\GordianKnot\vstrip.exe @"H:\DVD\Rips\dvddecrypter_VTS_04_PGC1\VobList.lst " -i"H:\DVD temp folders\dvd decrypter\VTS_04_0.IFO" -p0 -j0 -$1024 -o"H:\DVD\Rips\dvddecrypter_VTS_04_PGC1\VTS_04.V OB"
    9:50:00 PM: Creating project folder "H:\DVD\Projects\dvddecrypter_VTS_04_PGC1\"
    9:50:00 PM: dvd2avi
    9:50:00 PM: Demuxing track 1
    9:50:00 PM: Indexing with C:\Program Files\GordianKnot\DVD2AVI.exe -IA=1 -FO=0 -CS=2 -YR=1 -TN=1 -IF=[H:\DVD\Rips\dvddecrypter_VTS_04_PGC1\VTS_04_1.VOB, H:\DVD\Rips\dvddecrypter_VTS_04_PGC1\VTS_04_2.VOB] -OM=1 -DRC=0 -DSD=0 -DSA=0 -OF=[H:\DVD\Projects\dvddecrypter_VTS_04_PGC1\dvddecryp ter] -exit
    9:50:00 PM: Error: Indexing/demuxing failed: Can't create process.
    9:50:00 PM: END RIP "dvddecrypter" (0 hours, 04 minutes, 36 seconds)
    9:50:00 PM: Warning: Log shows 1 error message
  2. figured it out... when you install the rippack from the doom9 website, it installs r2r and tells it the wrong location for dvd2avi
