I have two 800MB SVCD MPGs and I needed to burn them so I did CD1 and that went fine then I tryed and burn CD2 with Nero (Same program I used to burn CD1) and it told me that it wasen't proper or something like that so I choose re-encode but that didn't work so I chose just to burn as is but that didn't work either. I also downloaded two other programs but to my susprise they wouldn't work either (Weren't considered a valid SVCD) so I want to know what can I do to get this burn and working like the first one.
I'm faily new to this kind of thing so sorry if I'm making a stupid mistake, and if you need to know anything else just ask and I'll tell you.
Try using VideoToolbox to examine the two video files. There is apparently something wrong with one of them. Take a look to the left under SVCD to see what the standards are.
You may also consider downloading VCDGear and have it check the video for errors. It's output just might produce a compliant SVCD for you.
Cheers, Jim
My DVDLab Guides -
have you tried buring it as a non stantard svcd? should burn just fine that way if its under 800 megs. that only other question is can you dvd player play non standard vcds?
How Big A Boy Are Ya?
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 12:39
