I've tried reading and testing out a few guides but i cant seem to find the one that suites me, can any1 help? I have many anime files that do have subtitles that i want to burn on dvd with menues and stuff. i keep either losing the subtitles or the audio. Thanks for helping
--grimm
What format are the files (divx, xvid, vcd) ? Are the subtitles seperately embedded, or part of the video itself ? What format is the audio ?
A little more information so we can give you a useful solution. -
sorry i didnt throw out that info. the files are .avi and i think the subtitles are not embedded, but not sure. it says "subtitles by blah blah blah" in the beginning, and some different files are done by different guys. also when i tried converting it in TMPGEnc, it kept the video but lost the subtitles. I could really use some help, thanks
--grimm -
yes, they appear in windows media player and PowerDVD. Im sorry this sounds like a total mess, but i just need a little help and ill be able to figure it out. some files are different resolutions too, do they all need to be the same?
--grimm -
I think they are asking you if the subtitles are selectable and/or removable. But from the way it sounds, by your responses, they are not. They probably are hard-coded into the video.
How far along into the process are you? Have you, or can you at least get to the part of encoding from divx-to-mpeg2? If so, then you just really need an authoring program.
And have you tried any guides? If so, which, and what part(s) exactly did you have a problem with? This might help us find what you might not be doing exactly right, or the guide might be flawed and we can help with a workaround step perhaps.
I hope I can be of some help.Blah, blah, blah
Restouring Anime
By LeoHenrique in forum RestorationReplies: 55Last Post: 21st Aug 2011, 13:48 -
Anime encoding help
By carasy in forum Video ConversionReplies: 3Last Post: 28th Nov 2010, 19:07 -
Anime Aspect Ratio
By Alexstarfire in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2010, 03:06 -
Encoding anime
By prnoct90 in forum Video ConversionReplies: 3Last Post: 25th Nov 2009, 06:38 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31
