  1. when i am ripping everything goes fine, all the files are on my hard drive and I am able to watch them, but when i try to burn them using dvddecrypter nothing is burned. All the preferences are default. It seems like the video_ts folder is not being opened or burned. I am using a pioneer 106 and my shrink and decrypter are the latest versions.
    Please help!!!
    Apr 2003
    Maryland
    ....but do you have Nero Burning Rom istalled and have you told Shrink to burn - having also chosen your DVD burner?
    You must have Nero installed and since you do not mentio anything about Nero,,,, that's your problem. Try that.
    If you do have Nero then I'm not quite sure why it will not burn. It work 100% with my setup!
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. I have never downloaded nero burning rom. Is this free to download?
  4. DVDDecrypter only burns ISO images. So when the backup window appears in DVDShrink, you have to specify that it create an ISO image. Also, tick the box that says launch DVDDecrypter to burn image. You don't need to buy Nero if you don't have it already.
    Pull! Bang! Darn!
  5. I have never downloaded nero burning rom. Is this free to download?
  6. is this not already in the preferences in dvdshrink to create ISO image? Also, when i get done ripping dvddecrypter already comes up to do the burning.
    Apr 2003
    Maryland
    That's why shrink will not burn! Yes you DL for free as a demo. You will need to buy a serial # to activate[/b]
    Feb 2004
    WI.
    No DVDShrink does not set to create ISO image files by default. Atleast it did'nt in my case. I had to manually set it to. Then use DVDDecrypter to burn the file. Should work fine then.
