  1. I want to make a 2 camera mix of a video shot from 2 different angles. I have 1 audio source to use, how can i mix the 2 with the one audio source? Can i do this without final cut?
    Also, if its easier, how do i make a dvd withthe option to select multiple angles? can i do this with dvd studio pro?
    any other way i could do this, i have imovie, ffmpegx, sizzle, basicall the basics.
    thanks
    eric
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    I'm pretty sure you can have multiple angle shots with iMovie, extract the sound track, and paste parts from the various video tracks into the timeline's video section. No problem. As for multiple angles on DVD, DVD Studio Pro can handle that, though I'm not quite sure how to go about it, personally.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  3. Putting angles is sort of a minor pain. If you have access to FCP, that may help a lot. My best advice (since it is sort of a long process... is to go by borders or barnes and noble and check out the Apple training book (I think the cover is red and white (or yellow and white)) and read the chapter. I'll go over my notes and see if I can find how to do this and I'll post it when I can Peace-
