  1. Is there a way to make GSpot make out a report so that while using these forums i could just load that up and copy and paste it in the forum with my question?
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Options>Export. Check off "Enable Exporting". Adjust the output folder as needed and click save as default. The next time you open a movie a text file will be created.
  3. AWESOME !!! WORKS PERFECT, THANX.
