  1. Just got a Pan E50 and recorded a TV show using DVD-RAM. How would I go about convering to DVD-R or DVD+R.
    lg4040
    win98se
  2. I should have stated using Win98SE.
  3. There are two ways to find out. The easiest would be a forum search, and the other way is to post and make someone else find it for you: https://www.videohelp.com/forum/viewtopic.php?t=218459
  4. My method is to use one of the following programs to import from DVD-RAM to hard drive, then author and burn to DVD-R:
    TMPGEnc DVD Author (recommended)
    Ulead DVD MovieFactory
    I use 98SE as well, and I noticed that if the DVD-RAM is close to full, these programs don't recognize the VRO file any more. I presume this is because the VRO file is over the 4GB limit that 98SE will recognize.
  5. Thanks
    elkfir,
    I downloaded and installed tmpgenc. I was able to look at the ram file and I haven't finished converting. Thanks again.
  6. It worked and I cutout the commercials.
  7. Great, glad it worked!
    (I frequently keep commercials tho, they're fun to look at years later )
