i have a collection of about 100s of avi's.. all about 22 minutes in length in a divx3.11 format.. each file is about 90 megs at 352x240 resolution.. id like to make some dvd's of these to watch... can anyone reccomend the easiest way to do this...i would liek to fit as many files on the dvd as possible.. the quality is kind of crappy right now, so im fine with that...
should i use like ulead dvd creator or whatever and let it convert the files(i think this will make the video files quite big)
convert to mpeg1?(i heard i will have to set the audio to 48khz? is there an utility to do this without splitting the files opening them up in an audio editor and resaving it then rencoding the the new wav track???
or can anyone recommend another method
Sound like you got it covered. You can convert to Mpeg1 or Mpeg2, and still keep the resolution as it is (NTSC, be sure your framerate is 29.97). Max video bitrate for MPeg1 on DVD is 1800 something. Unless your Audio is MP3 VBR it should be ok to let your encoder do the audio and video together, both TMPGEnc and CCE will do it for you, CCE being easiest for batch encoding, just drag and drop all the files to convert. Or use the separately available batch-tool for TMPGEnc if you have no hurry.
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Finished my WMM project, saved as avi file-7.35gb. Now what?
By jbitakis in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2008, 12:27 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..
By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 15:04 -
No audio after converting project to AVI
By gwlnl in forum AudioReplies: 3Last Post: 23rd Nov 2007, 14:55
